• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    ADN Support Specialist
    Check out the self-paced guide “My First Plug-in”
    5193 Views, 13 Replies
    08-05-2011 01:04 PM
    Check out the Self-Paced Guide “My First Plug-in” presented by the ADN Inventor Team
    www.autodesk.com/myfirstinventorplugin
    Are you an Autodesk Inventor power user with an interest in becoming even more productive? Would you like to automate or extend the capabilities of Inventor, but are new to computer programming? If so, then this guide is designed for you.
    “My First Plug-in” is a self-paced tutorial guide for a smooth introduction into the programming world. This is a “one-stop shop” learning path for users who know Autodesk products but are absolutely new to programming and are thinking about taking the plunge. In this guide, you will be working with the Autodesk Inventor API and the VB.NET programming language.
    There are many resources available on the web for you to learn about the Autodesk Inventor API (Application Programming Interface), however, these resources tend to be designed for people who already know programming. This guide is different: it assumes no previous programming knowledge and yet helps you build your first plug-in quickly, without swamping you with details. You will have a working application within an hour of starting this material, irrespective of your current level of programming expertise.
    The guide will start by reviewing the benefits of customizing Autodesk software before progressing onto lessons covering the use of the Autodesk Inventor API. The lessons will start by building a working plug-in before covering more detailed explanations of the underlying principles and further developing the application’s functionality.
    Product: Autodesk Inventor
    Programming Language: VB.NET
    Application Programming Interface (API): Inventor API
    If you have any feedback on this new guide let us know at myfirstplugin@autodesk.com
    Wayne Brill
    Developer Technical Services
    Autodesk Developer Network
    Please use plain text.
    *Expert Elite*
    ScottMoyse
    Re: Check out the self-paced guide “My First Plug-in”
    08-05-2011 08:16 PM in reply to: wayne.brill
    this is great, will definitely be checking this out, how come this post is here instead of in the customisation forum?
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    Distinguished Contributor
    08-06-2011 12:56 AM in reply to: ScottMoyse
    Does this apply to all recent Inventor version?  Sorry not read it yet but will certainly be doing so.  Great idea.
    AutoCADM 2011 SP2
    XP 32-Bit SP3
    08-09-2011 05:56 AM in reply to: wayne.brill
    haven't read it yet, but I love the idea and hope to take a look at it real soon.
    Larry Marshall
    2013 Product Design Suite Ultimate
    Windows 7 Sp1
    Intel(R) Core (TM) i5-2400 @ 2.00GHz
    3.00 GB of RAM
    AMD Radeon HD 6570
    09-15-2011 11:56 AM in reply to: wayne.brill
    Great thanks!!!
    *Expert Elite*
    Cadmanto
    12-28-2011 05:55 AM in reply to: wayne.brill
    Thanks Wayne.  I am not a power user.  Infact I am barely a newbe user, but being a Solidworks
    power user and just learning how to use Inventor, I will take all of the helpful tools I can get my hands on.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Active Member
    04-23-2012 02:25 PM in reply to: wayne.brill
    Absolutely, I'll do it when I get home.
    New Member
    04-30-2012 02:28 AM in reply to: palmhat
    Thanks dude, had the same issues .
     thanks
    IT Security expert @oppida & 3D afficionados
    05-13-2012 10:41 AM in reply to: wayne.brill
    I've managed to hack my way through VB.NET via example code in order to streamline my Inventor use but will gladly go through this tutorial.
    Valued Contributor
    jyothissurendran
    10-28-2012 04:22 AM in reply to: wayne.brill
    Thanks a lot Wayne Brill !!!!
    Jyothis Surendran
    Inventor Professional Suite 2010
    Windows 7
