Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Changing multiple face colors
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi folks,
I'm working with Autodesk Inventor 2009.
I have several parts colored in gray, black and red.
- The grey color is the basic part color/material.
- The black color is feature color styles.
- The red color is face color styles.
I need to change all the face color styles (red) to the original part color/material (gray/default). I can do this by right-clicking on a surface > properties > face properties.
My problem is that I have a lot of surfaces (mostly due to fillets). I can choose multiple ones wth ctrl + click, but even that would take forever.
Is there an easier way to change all the face colors at once?
Best regards
A. Heiselberg
Re: Changing multiple face colors
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi! If you were on R2010, it would be fairly simple to do. Just right-click on the solid body node in the browser -> Properties -> Strip color overrides. However, you are on R2009.
On top of my head, there are three ways to do this without actually selecting the faces manually.
Option1: You can simply rename the document color style from Red to something else. Then change the color to be like gray.
Option2: You can find a planar face or any face on the part. Create a zero-offset surface on the face. Then use Delete Face command to delete the selected face. Next, create another zero-offset surface using Qulit option. Use Delete Face command to remove the original quilt. Lastly, use Sculpt or Stitch to turn them into a solid again. This workflow is a bit confusing. Please see attached part for more information.
Option3: If you are familiar with VBA, you might be able to create a small program marching over the faces and resetting the face color to something else.
Thanks!
Principal SQA Engineer, Inventor
Manufacturing Group
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your help. I managed to get it done in a way similar to your 1st solution.
Thanks again!
BR
A. Heiselberg
