• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Changing multiple face colors
    379 Views, 2 Replies
    10-01-2012 06:22 AM
    Hi folks,
    I'm working with Autodesk Inventor 2009.
    I have several parts colored in gray, black and red.
    • The grey color is the basic part color/material.
    • The black color is feature color styles.
    • The red color is face color styles.
    I need to change all the face color styles (red) to the original part color/material (gray/default). I can do this by right-clicking on a surface > properties > face properties.
    My problem is that I have a lot of surfaces (mostly due to fillets). I can choose multiple ones wth ctrl + click, but even that would take forever.
    Is there an easier way to change all the face colors at once?
    Best regards
    A. Heiselberg
    Please use plain text.
    Employee
    Re: Changing multiple face colors
    10-01-2012 03:42 PM in reply to: aheiselberg
    Hi! If you were on R2010, it would be fairly simple to do. Just right-click on the solid body node in the browser -> Properties -> Strip color overrides. However, you are on R2009.
    On top of my head, there are three ways to do this without actually selecting the faces manually.
    Option1: You can simply rename the document color style from Red to something else. Then change the color to be like gray.
    Option2: You can find a planar face or any face on the part. Create a zero-offset surface on the face. Then use Delete Face command to delete the selected face. Next, create another zero-offset surface using Qulit option. Use Delete Face command to remove the original quilt. Lastly, use Sculpt or Stitch to turn them into a solid again. This workflow is a bit confusing. Please see attached part for more information.
    Option3: If you are familiar with VBA, you might be able to create a small program marching over the faces and resetting the face color to something else.
    Thanks!
    Principal SQA Engineer, Inventor
    Manufacturing Group
    Autodesk, Inc.
    Active Member
    10-02-2012 12:14 AM in reply to: johnsonshiue
    Thank you for your help. I managed to get it done in a way similar to your 1st solution.
    Thanks again!
    BR
    A. Heiselberg
