• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Johnson, Bob
    Changing Templates in a file?
    36 Views, 3 Replies
    11-24-2002 01:48 PM
    I created a sketch in a file using a standard.ipt Template and I should have
    used a Sheet metal.ipt template. So, now I can't access the Style and Face
    tools on the Sheet metal Panel Bar. Is there a way to exchange Templates in
    a file? Thanks, Bob
    Please use plain text.
    *Hedlund, Jan
    Re: Changing Templates in a file?
    11-24-2002 02:01 PM in reply to: *Johnson, Bob
    Choose Application/Sheet Metal, then you get all the commands.
    /Janne
    "Bob Johnson" skrev i meddelandet
    news:A5C50EFE16D578ECD96F22FB0FE01101@in.WebX.maYIadrTaRb...
    have
    Face
    in
    > a file? Thanks, Bob
    *Jeffrey, Dennis
    11-24-2002 02:12 PM in reply to: *Johnson, Bob
    Applications > Sheet Metal
    Dennis
    > a file? Thanks, Bob
    Dennis Jeffrey
    CAD Associates - Fort Wayne
    Autodesk University Instructor
    Autodesk ASC
    (260-432-9695 x 221
    *Keller, Kent
    11-24-2002 02:26 PM in reply to: *Johnson, Bob
    If you have some things such as materials setup in your sheetmetal template
    and you have only done one sketch, it may be worth it to start a new part
    using the right template, and then copy the sketch and paste it in the new
    ipt file.
    Otherwise do as the others suggested.
    Kent Keller
    Member of the Autodesk Discussion Forum Moderator Program
    http://www.MyMcad.com/KWiK/Mcad.htm
    "Bob Johnson" wrote in message
    have
    Face
    in
    > a file? Thanks, Bob
