• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    Cadmanto
    Accepted Solution
    Changing Radius Dimension to Diameter
    679 Views, 4 Replies
    07-09-2012 09:16 AM
    How do I change this dimension into a diameter dimension?
    I have tried editing the dimension style to display as a diameter and it doesn't change it.  I tried creating a new dimension style and it doesn't change it.  So thus the question.
    Best Regards,
    Scott McFadden
    (Colossians 3:23-25)
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Changing Radius Dimension to Diameter
    07-09-2012 09:17 AM in reply to: Cadmanto
    Hi Cadmanto,
    If you right-click while creating the dimension (select the curve, then right click), you can toggle it to a diameter dimension.
    Will that work?
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    *Expert Elite*
    Cadmanto
    07-09-2012 09:21 AM in reply to: Curtis_Waguespack
    Yes, that will and did work quite nicely!!!  :smileyhappy:
    Thank you.
    So why can't it be changed after it is created?  Is this a bug in the software?
    Best Regards,
    Scott McFadden
    *Expert Elite*
    Curtis_Waguespack
    07-09-2012 09:26 AM in reply to: Cadmanto
    Hi Cadmanto,
    Not a bug since it's functioning "as designed", but it's certainly a limitation.
    I know you're aware of feature enchancement link, but I'm posting this in case someone else sees this and thinks it would be a good idea too.
    http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
    I hope this helps.
    Curtis
    *Expert Elite*
    Cadmanto
    07-09-2012 09:29 AM in reply to: Curtis_Waguespack
    Hey Curtis,
    Ok, fair enough.
    Yes, I know of that link thanks to you and I think I will suggest this as
    an enhancement.
    Best Regards,
    Scott McFadden
