• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Change part reference in drawing
    155 Views, 7 Replies
    02-02-2013 04:01 AM
    In solidworks, if I have several similar parts to draw, I can draw one part and annotate it and then to save time and effort I can save the drawing as one of the other parts and then change the part reference in the drawing as I open it up.
    Is this possible in Inventor?
    Thanks texteditor.
    Please use plain text.
    Active Member
    gjohnston
    Re: Change part reference in drawing
    02-02-2013 04:03 AM in reply to: texteditor
    I do this often. Open ipt then save as new part.
    Active Member
    02-02-2013 07:20 AM in reply to: gjohnston
    Sorry not clear enogh in my explanation - in solidworks have 2 similar parts and do drawing of one with all sorts of views and annotations.
    Then save drawing as drawing of second part and change reference in drawing to refer to second part _ drawing then opens up with similar drawing to first part but with all the views containing and referencing second part.
    texteditor
    Active Member
    gjohnston
    02-02-2013 08:21 AM in reply to: texteditor
    Not that I know of. Sounds like a good idea. I'd vote for that. Have a nice day. Gerry
    Distinguished Mentor
    02-02-2013 09:48 AM in reply to: gjohnston
    Doesn't Manage>Modify>Replace Model Reference do the same thing?
    Active Member
    gjohnston
    02-02-2013 10:04 AM in reply to: rdyson
    I did not know that was there. Thank you so much. That should make my life easier. Have a nice day. Gerry
    Valued Mentor
    02-02-2013 04:38 PM in reply to: texteditor
    Using iParts will get you what you are after.
    Best Regards,
    Igor.
    Web: www.meqc.com.au
    Active Member
    02-03-2013 09:52 AM in reply to: rdyson
    Exactly what I wanted.
    Thanks texteditor.
