• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Change color of parts
    277 Views, 6 Replies
    12-23-2012 11:34 PM
    Inventor pro 2013 - how do I change the color of a part.
    Inventor 2012 had a menu called Color Override that I can't find now.
    Alon
    Please use plain text.
    *Expert Elite*
    Re: Change color of parts
    12-24-2012 04:54 AM in reply to: alon
    You can change by part, by body, by feature or by face.
    Should be the same as in 2012.
    Can you attach file here or at least screen capture of your browser?
    *Expert Elite*
    blair
    12-24-2012 10:10 AM in reply to: JDMather
    The biggest difference, in 2013 as it has really been split into Material and Appearance. Material will have a standard stock appearance, but contains the physical properties of the material. Whereas the appearance only contains the finish of an item.
    As JD stated, they are still applied the same way.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    *Pro
    12-24-2012 01:45 PM in reply to: alon
    Are you wanting to change the color of a part in an assembly, or in the part file?
    In an assembly, select the part (not face or subassembly), then choose the Appearance you want from the dropdown at the top of the screen.  In a part file, with nothing selected, or the entire part selected in the browser, choose the Appearance as above.
    Member
    12-24-2012 10:40 PM in reply to: alon
    Member
    03-14-2013 01:58 AM in reply to: alon
    Hi there
    I hope it's ok to drop a remark here, instead of making yet another post.
    What if the scenario is a welded assembly that ends up being painted or galvinized? I would like to select same color override option as in parts. Can it be done?
    Best Regards
    Morten
    *Expert Elite*
    blair
    03-14-2013 09:53 AM in reply to: mortenrisumhansen7822
    same
    Win7-64
