• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Rasmussen, Egon
    Change Part Number in multiply files
    84 Views, 7 Replies
    11-25-2002 03:43 PM
    Hi There
    How can I change the "Part Number" Field in Thousands of .ipt files.
    Part Number Field = Filename
    Used the same "Mother.ipt" to create all files, but to change 8000 files
    manually
    I´snt that funny.
    Thanks in Advance
    Egon Rasmussen
    SikaMatec
    Denmark
    Please use plain text.
    *KJohnson
    Re: Change Part Number in multiply files
    11-25-2002 08:36 PM in reply to: *Rasmussen, Egon
    VBA would do it easily. Check out the sample in the SDK directory under
    Iventor 6 and the Programming help. Also check out the
    autodesk.inventor.customization. Look in the FAQ posted yesterday for the
    link.
    Kathy Johnson
    "Egon Rasmussen" wrote in message
    news:6131FF78E1F7BC8CD96CECB562261F1A@in.WebX.maYIadrTaRb...
    > Hi There
    > manually
    > I´snt that funny.
    > Thanks in Advance
    > Egon Rasmussen
    > SikaMatec
    > Denmark
    Active Member
    Re:
    11-25-2002 09:10 PM in reply to: *Rasmussen, Egon
    Hi Kathy
    Thanks, but I was looking for a more automatic
    kind of feature.
    Like: Point on a folder, and all .ipt in all subfolders will obtain "Part Number" as filename.ipt
    Egon
    JRS
    Member
    Re:
    11-25-2002 09:38 PM in reply to: *Rasmussen, Egon
    Try using the Design assistant, select all the files to change by holding down the shift or control key. Then right mouse click, pick Properties and change the field, this will update all the selected files.
    *KJohnson
    Re:
    11-25-2002 10:01 PM in reply to: *Rasmussen, Egon
    The only problem is that he wants each file to have
    a different entry in that property.
    Kathy Johnson
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Try
    Active Member
    Re:
    11-25-2002 10:38 PM in reply to: *Rasmussen, Egon
    HI
    Yes... You are right Kathy, thats the problem.
    You know that the "Part number" field (the first time the part is saved) obtain the filename.
    But if you have 8000 parts with the same filename, written
    in that "Part number" field, your lost.
    Dont know how to do ?.
    Thanks a lot for all your answers.
    Egon Rasmussen
    *J, Dave
    Re:
    11-26-2002 01:10 AM in reply to: *Rasmussen, Egon
    So what you really want is an FM button? (F***ing
    Magic)
    HI
    But
    in that "Part
    Egon Rasmussen
    *KJohnson
    Re:
    11-26-2002 01:36 AM in reply to: *Rasmussen, Egon
    The VBA program will do the job without opening
    everyfile.  It will take less time then doing it manually.
    Kathy Johnson
    Magic)
    HI
    You know that the
    in that
    Egon Rasmussen
