• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Change Direction of Velocity in Dynamic Simulation
    73 Views, 0 Replies
    01-28-2013 11:05 AM
    I am trying to simulate the motion of a box on a conveyor transitioned to a tilt tray. The box will move along the conveyor until it reaches the tilt tray, at which point the box will be positioned on top of the tilt tray and begin to move along the direction of the tray.
    The following video somewhat illustrates what I am trying to do. Instead of people placing items on the trays as in the video, I will have a conveyor sliding items onto the trays:
    http://www.youtube.com/watch?v=xU6gTu26mk0
    I can manipulate the box and tray to move to the end of the conveyor, but I do not know how to switch the direction of travel for the box so that it moves with the tray. For simplicity, both are traveling at the same velocity.
    I do not know how to constrain a part/subassembly along a path defined by a sketch (constrained to a sketch line, not to a 3-D edge or face). This would be the easiest way to do this. The box doesn't actually need to "catch" on to the surface of the tray. It just needs to visually move onto the tray, then move at the same speed and direction of the tray.
    I have attached an example assembly and added some spatial joints and velocities in Dynamic Simulation.
    _____________________________________________________________
    Autodesk Product Design Suite Ultimate 2013 | Windows 7 Professional 64 bit, SP1
    Dell Precision T7600 | Two (2) Intel Xeon CPU E5-2630 @ 2.3GHz (12 cores, 24 logical processors) | 32 GB RAM
    Please use plain text.
