• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Chamfer to a curved edge
    259 Views, 7 Replies
    03-04-2013 12:40 PM
    Hello All,
    In Autodesk Inventor 2013. I have a simple cylinder extrusion with a rectangle attached to the cylinder. Drawing file attached(extrusion 1). Whenever I apply a chamfer to one of the straight edges, Inventor generates negative taper on the cylinder wall (if you zoom in with a window, you can clearly see that their are two lines on the cylinder wall where the chamfer edges was applied).
    Is there anyway to prevent this from happening? This gives me all sorts of problem in my CAM software because the tool is trying to machine in an area it cannot get to.
    As a work around I have to create a new part file with a small gap between the cylinder and the chamfered edges. This keeps the cylinder edges nice and straight with no taper. The work around is attached as well. Since the tool can't go that far into the corner given the radius of the tool, the gap has no affect on me generating code. I have tried many different ways on creating this part with chamfers with no luck. Once the chamfer is generated, it should match the profile of the cylinder. This is absurd.
    Please use plain text.
    Distinguished Mentor
    Re: Chamfer to a curved edge
    03-04-2013 01:02 PM in reply to: dcmorgan
    CAn you post a screen grab of the problem. I'm not seeing it.
    03-04-2013 01:07 PM in reply to: rdyson
    Set your view to wireframe and zoom in or scroll in to where the cylinder and chamfered edge meets. You can see it clear as day.
    03-04-2013 01:18 PM in reply to: dcmorgan
    I don't see it.  Furthermore I don't understand how the "workaround" solves the "problem".
    Can you attach screen shot of what you are seeing?
    OK, I finally found it.  You could have included the information to look at it from Front view.
    Edit:  well now I'm not sure I'm seeing anything other than a graphics artifact.
    Inventor Professional 2014 Edu 64-bit
    03-04-2013 03:07 PM in reply to: dcmorgan
    In wireframe, show me where the taper starts. If the entire surface tapers, why is the intersection of the retangle and cylinder 90° to the base?
    rhasell
    03-04-2013 08:31 PM in reply to: rdyson
    I would normally palm it off to graphics, but since your CAM software complains, try the following.
    Edit Extrusion9 and set it to a new solid.
    It appears to graphically solve the issue, but I am not sure what your CAM software will do?
    Reg
    Autodesk Product Design Suite Premium 2014 Build 170
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home) - 12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    03-05-2013 05:21 AM in reply to: rhasell
    ok thanks, I will try that
    Distinguished Contributor
    03-05-2013 05:53 AM in reply to: dcmorgan
    You might try modeling it as a multipart model, do your chamfers on the appropriate solid and then combine the two solids when done. Could not open yours, am using 2011, but you should be able to open my sample if you are running a later version.
    Steven White
    Lee C. Moore, Inc.
    www.lcm-wci.com
    Inventor 2011
    Intel Dual Xeon E31225 @ 3.1 GHz CPU
    16 GB RAM
    NVIDIA Quadro 600 GPU
    Windows 7 - 64 Bit
