• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Chamfer set length
    191 Views, 4 Replies
    01-17-2013 01:59 PM
    I searched and found numerous topics on this issue, all of them over 3 years old, so I guess it might be worth asking again.
    I'm wondering if there is any way to chamfer a set length along an edge (similar to what can be done with flanges in sheet metal mode), as opposed to the entire length of an edge.
    _____________________________________________________________
    Autodesk Product Design Suite Ultimate 2013 | Windows 7 Professional 64 bit, SP1
    Dell Precision T7600 | Two (2) Intel Xeon CPU E5-2630 @ 2.3GHz (12 cores, 24 logical processors) | 32 GB RAM
    Please use plain text.
    Curtis_Waguespack
    Re: Chamfer set length
    01-17-2013 02:08 PM in reply to: j_berry
    Hi j_berry,
    You might have found this link in your searches, but if not there is an example file attached there that might help:
    http://forums.autodesk.com/t5/Autodesk-Inventor/How-to-stop-chamfer-before-the-corner/m-p/3275375
    And here is the link from that page that seems to have changed:
    http://cadsetterout.com/inventor-tutorials/ifeature-stopped-chamfer/
    You might also post your improvment idea to have an option to have it work like a sheet metal flange here:
    Inventor IdeaStation
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    blair
    01-17-2013 10:54 PM in reply to: j_berry
    No, due to the nature of the fillet algorithim, it would know how to deal with the start and end face on the chamfer.
    You would need to create a work plane and sketch using the Extrude-Cut
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Valued Contributor
    01-18-2013 01:11 AM in reply to: blair
    Is the nature of a fillet algorithim different then a fillet? Because in a fillet it's posible. In the fillet option you can create a variable radius by placing points and change the radius to zero. Why not use this for a chamfer?
    Rob.
    Autodesk Inventor 2012 Certified Associate & Autodesk Inventor 2012 Certified Professional.
    Software in use: Inventor 2013, SolidWorks 2011
    Also experience with: Solid Edge untill ST4,
    Valued Contributor
    01-18-2013 05:19 AM in reply to: Curtis_Waguespack
    Curtis_Waguespack wrote:
    Hi j_berry,
    No, that topic had not come up in searches. A similar topic on that second link was exactly what I was looking for - the stopped chamfer with curved ends (Lark's tongue chamfer - http://cadsetterout.com/inventor-tutorials/ifeatures-larks-tongue-chamfer/ ). Thanks!
