• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Fred Payne
    Center point visibility : dwg import
    262 Views, 8 Replies
    09-17-2009 01:12 PM
    I imported some dwg blocks into Inventor with the
    idea that I use them in conjunction with other parts in an
    assembly.
    Having done so, I can't hide the center points. Any
    suggestions? Am I missing something obvious? See attached view.
    I need a cure for imeasles.
    Lawrence
    IV series 2010
    Please use plain text.
    Employee
    Re: Center point visibility : dwg import
    09-21-2009 10:15 AM in reply to: *Fred Payne
    There currently is no way to supress the visibility of the sketch point geometry but we are looking into the issue. Thank you!
    Ralf Walter (Autodesk)
    *Fred Payne
    09-21-2009 10:48 AM in reply to: *Fred Payne
    OK. Thanks. I got a lot of work to do then recreating.
    regards .............. Spotty Muldoon Esq.
    "ralfwalter" wrote in message news:6257767@discussion.autodesk.com...
    Active Member
    10-24-2012 01:02 AM in reply to: *Fred Payne
    I got the same issue here, and i wonder if there is already a solution for this problem. (because the thread is from 2009). I'm using inventor 2013.
    Valued Contributor
    02-04-2013 04:51 AM in reply to: ralfwalter
    i also get into the same issue
    is there something done meanwhile?
    *Expert Elite*
    02-04-2013 07:40 AM in reply to: michael.marx
    You could set Tools>Application Options>General tab to a real small value on Annotation Scale to make them less visible, but this will also make sketch dimension annotations very small.
    http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
    Inventor Professional 2014 Edu 64-bit
    Valued Contributor
    02-04-2013 07:44 AM in reply to: JDMather
    Thank you for the input but that´s not what i´m searching for
    *Expert Elite*
    02-04-2013 08:04 AM in reply to: michael.marx
    No.
    New Member
    04-03-2013 04:38 PM in reply to: *Fred Payne
    I just found that by going to properties for the sketch into which you've imported the ACAD drawing, you can change lineweight and all the points become far less prominent.
