Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Center point visibility : dwg import
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
idea that I use them in conjunction with other parts in an
assembly.
suggestions? Am I missing something obvious? See attached view.
Lawrence
Re: Center point visibility : dwg import
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There currently is no way to supress the visibility of the sketch point geometry but we are looking into the issue. Thank you!
Ralf Walter (Autodesk)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
regards .............. Spotty Muldoon Esq.
"ralfwalter" wrote in message news:6257767@discussion.autodesk.com...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got the same issue here, and i wonder if there is already a solution for this problem. (because the thread is from 2009). I'm using inventor 2013.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i also get into the same issue
is there something done meanwhile?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You could set Tools>Application Options>General tab to a real small value on Annotation Scale to make them less visible, but this will also make sketch dimension annotations very small.
http://forums.autodesk.com/t5/Inventor-IdeaStation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for the input but that´s not what i´m searching for
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
michael.marx wrote:i also get into the same issue
No.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just found that by going to properties for the sketch into which you've imported the ACAD drawing, you can change lineweight and all the points become far less prominent.
