• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    wolf1o
    Center of mass/gravity location
    264 Views, 4 Replies
    10-21-2011 08:04 AM
    How can see visually the center mass of a part or assembly?
    When I'm checking in the Iprop., I see the center of gravity coordinates, but it there a way to "see" it (some visual representation)
    Thanks!
    Inventor 2012 Pro.
    I7 workstation
    Valued Contributor
    GSE_Dan_A
    Re: Center of mass/gravity location
    10-21-2011 08:05 AM in reply to: wolf1o
    In the ribbon click View.
    At the left side you should see Center of Gravity.
    Click this button.  Prompt willl notify you that the Center of Gravity is Out of Date.  Click OK
    GSE Consultants Inc.
    Windsor, ON. Canada
    New Member
    PeterNouth1839
    02-08-2012 02:42 PM in reply to: wolf1o
    HI ALL
    I have an issue with CG function.I have an 3d model that one end is heavier than the other end,so the CG should be at
    the heavier end where the mass is concentrated but it shows the CG at the other end.The question can the user trust this CG in this Inventor? Or should I upgrade the service pack to the next version?
    Pete
    *Pro
    02-08-2012 03:43 PM in reply to: wolf1o
    When ever service pack's are available, it's always advantageous to install them. They are done to fix known issues.
    If your COG looks out of place and funny. Take an in depth look at the materials in each of the IPT's. It's easy to create a IPT from "Default" and not have the proper mass of the item or the correct COG because of the incorrect material and mass.
    IV2013 Ultimate / Autodesk Sim 2013
    Win7-64
    EVGA X58 - Classified, iCore7 990 24Gb Trip-Channel
    480Gb (2 x 240Gb SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-590 Classified - 301.42
    SpacePilot 3.15.3 / 6.15.3 / 3.12
    Distinguished Mentor
    02-09-2012 05:05 AM in reply to: PeterNouth1839
    Any non-native parts?  I seem to recall folks having mass issues with imported parts, but can't recall the particulars - maybe parts not being solids but surfaces?
    KState92
    Inventor Series 2010 SR SP4
    Windows 7 64 bit - SP1
    8 GB Ram
    Quadro 2000
