• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Cannot snap to sketch line midpoint (no green dot) 2013
    367 Views, 6 Replies
    11-26-2012 08:28 PM
    Hi All
    Hopefully this is an easy one...
    When I use a tool such as 'move'/'select base point' in the sketch environment, I used to be able to select line midpoints.
    Is this no longer possible?
    My constraint options seem to be fine...
    Recently upgraded to 2013
    Grant
    Please use plain text.
    Employee
    Xun.Zhang
    Re: Cannot snap to sketch line midpoint (no green dot) 2013
    11-27-2012 12:54 AM in reply to: ggoodey
    Hello, ggoodey
    Thanks for your question, unfortunately, the Mid Point not supported for base point selection so far, please create a contribution line which could snap to the Mid point first to help identify the real point for the base point when you try to move the sketch with Mid point.
    I will submit a wish to out internal system for enhancement in the future, thanks a again.
    Xun Zhang
    Software QA Engineer
    Inventor Quality Assurance Team
    Active Contributor
    11-27-2012 12:04 PM in reply to: Xun.Zhang
    Thanks Xun
    I was so sure I could do this pre-2013
    Never mind...
    Employee
    Xun.Zhang
    11-27-2012 05:33 PM in reply to: ggoodey
    Hello, ggoodey
    Checked in several release pre-2013, such as 2011 and 2012, your requirement not supported, a wish tracked in our system, we hope it will be fix in a short time, and I will let you know once it got fixed.
    Xun Zhang
    Active Contributor
    11-27-2012 05:43 PM in reply to: Xun.Zhang
    No worries!
    Thanks again
    Active Member
    11-27-2012 11:41 PM in reply to: ggoodey
    Hello !
    I tried to move a Sketch block ( Insert point selection)
    but could not.
    It will be usefull to select Midpoint  also Sketch block.
    Sorry,Long line !
    Inventor2012,2013
    Windows7 64bit
    Japan
    Employee
    Xun.Zhang
    11-27-2012 11:49 PM in reply to: yomogidami
    Hello, yomogidami
    Yes, we noticed that it will be better if mid point supported when sketch move, thanks for your follow up question, I'll reply you once it got fixed.
    Many thanks for your questions again.
    Xun Zhang
