• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Sands, Fred
    Cannot sketch using geometry in idw.
    42 Views, 6 Replies
    11-04-2002 02:52 AM
    It works in 5.3, but not 6.
    Extrude a rectangular, then create a .idw. Try to draw a line from corner to
    corner in sketch.
    5.3 the green dot shows up. 6.0 nothing.
    Bug or just a different method?
    Please use plain text.
    Member
    Re: Cannot sketch using geometry in idw.
    11-04-2002 03:00 AM in reply to: *Sands, Fred
    In the sketch of the IDW view you have to project the lines of the model first. (And don't forget to hit RMB and "done" after selecting the lines to project.)
    Michael Puschner
    *Keller, Kent
    11-04-2002 03:01 AM in reply to: *Sands, Fred
    you have to project in R6 or I think it was said that if you have Autoproject edges
    turned on in app options it will do it. I haven't verified that myself though.
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "Fred Sands" wrote in message
    news:8F667F2FD1F3D2EBF2BABAADB027D0B9@in.WebX.maYIadrTaRb...
    > corner in sketch.
    > Thanks
    *Sands, Fred
    11-04-2002 03:03 AM in reply to: *Sands, Fred
    That worked great!
    Thanks again
    to
    > corner in sketch.
    > Thanks
    Member
    Re:
    11-04-2002 03:06 AM in reply to: *Sands, Fred
    Autoproject edges doesn't work for me in IDWs.
    (And if I think about it they aren't edges in IDWs.)
    Michael Puschner
    *Keller, Kent
    Re:
    11-04-2002 03:15 AM in reply to: *Sands, Fred
    Hmmm I was just going off this previous post
    All,
    Just so everyone knows (I've seen this discussion before), if you go to
    Application Options and the Sketch tab, and turn on "Autoproject edges
    during curve creation", it will work as it did in previous releases. That
    is, sketch on a view and you can constrain to the model geometry.
    Just an FYI.
    Rich Willis- Autodesk
    Kent
    "MichaelPuschner" wrote in message news:f11f86d.3@WebX.maYIadrTaRb...
    > Michael Puschner
    Member
    Re:
    11-05-2002 02:01 AM in reply to: *Sands, Fred
    Now I've got it. In sketches of IDW views is has no effect when you change the "Autoproject edges" setting while you are in sketch mode. You have to leave the sketch and activate it again to see the effect. In IPT scetches the setting has an effect at once without leaving the sketch.
    So Kent is right, "Autoproject edges" workes in IDWs similar as sketching was in 5.3.
