• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    kaj.petersen
    Cannot read texture image
    905 Views, 3 Replies
    11-28-2010 05:25 PM
    When I start a new document or open a file in Inventor, I get a pop up saying: "Cannot read texture image C:\Useers\public\Documents\Autodesk\Inventor 2011\Textures\Chrome.dds"
     I moved the whole Autodesk file and changed all paths under settings>files in Inventor. The new path to Chrome.dds is C:\Users\Kaj\Documents\Autodesk\Inventor 2011\Textures\Chrome.dds
     Inventor works fine but the pop up is really annoying. What can I do about it?
    Thanks in advance.
    Please use plain text.
    Valued Mentor
    Re: Cannot read texture image
    11-29-2010 04:07 AM in reply to: kaj.petersen
    where did you say you specified the texture file path?
    the setting i know of from memory is found under application options, colours... filename. if you changed it there is it still doing it?
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    Member
    kaj.petersen
    11-29-2010 02:24 PM in reply to: kaj.petersen
    I didn't see that one, thank you very much!
    New Member
    11-14-2012 02:10 PM in reply to: Mark_Wigan
    Can you show me how to do that? I'm constantly experiencing an issue where I keep recieving a message stating "Cannot read texture image"
