Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot export face completely
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I made a part using the extrude function and cut some texts into the part by extrude (tried emboss) as well. However, when I select the face to export, letters that have area inside, such as "A", "O", etc don't like right because the face selection only selects everything outside the bounds of the letter- so the triangle island part in the "A" and the circular island part bounded by the "O" cannot be selected. This presents a problem for me as I'm trying to use a CNC to cut these letters out with a dxf file to feed my CAM program. Any help please?
Thanks!
Re: Cannot export face completely
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Why are you exporting the face for cnc? We use a step or dxf no need to export just the face.
Unless I am missing something.. ![]()
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If this is a sheet metal part then you can right click on the flat pattern and select the "Save as" option. This will export the geometery out in dxf fprmat all nicely layered out for your CNC software. If it's not sheetmetal then you'll have to make a quick 2D drawing with a view fo what you're trying to cut and do a save copy as of the dawing to dxf. This will give you everything including the titleblock all on one ugly layer, but you can clean it up in AutoCAD before sending it to you CNC software.
A picture or the .ipt file, would be helpful to us understanding what it is you are doing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've attached a picture depicting my situation- the yellow highlighted area is the area i sketched out- those are the sections that are not cut (same height as the face, so they are "islands" that I referred to in my last post). I want those areas to be selected as well along with the face. Right now the areas inside the bounded lines of the letters are not being selected even though they are at the same level as the face and they are not cut.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here's a 3d view of the problem- as you can see, the face is selected but not the isolated part (highlighted in yellow) even though I want it to be part of the face.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Help please, anyone?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not familiar with export face, but I imagine the problem is that those are not a part of the same face.
What format is your CAM software expecting?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you answer the question we ask?
Why are you doing it this way why are you just exporting the face when you can export the whole thing and get to the same place you want to go?
We are helping but we also need to understand why you are doing things so if there is a better and easier way we can tell you..
James Letcher
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm exporting it this way because my CAM software "CamBam" takes .dxf files. I don't understand why they aren't the same face since the cut extrude by the letter did not cut within the bounded areas of the letters.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It's not one face because it's not contiguous. Those are three seperate, but coplanar faces. Try my suggestion a few posts up. That's the method I use for programming our laser, it works great.
