• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Cannot connect fittings in tube and pipe
    132 Views, 2 Replies
    11-19-2009 08:31 AM
    Can anybody tell me what I'm doing wrong? I have a pipe run and have inserted a flange and a valve. I want to connect the two but I can't. When I use connect fittings it will not connect them. If I insert the valve off the pipe run and then connect fittings, it connects the valve to the cross fitting below the flance. See picture. I tried deleting the dimension to the node point for the valve insertion into the line but the valve still seems to be grounded.
    any help is greatly appreciated.
    Please use plain text.
    Distinguished Contributor
    Re: Cannot connect fittings in tube and pipe
    11-19-2009 08:44 AM in reply to: johnny01
    Johnny
    I have never used piping, but I question whether there is room enough for two flanges between existing flanges,
    something to look at.
    Maybe a custom machined close coupling?
    Thaddeus
    11-19-2009 08:48 AM in reply to: johnny01
    Thanks, but there is room. I just need to slide the flanged valve down and connect to the existing flange in there.
