• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Can you change template descriptions?
    103 Views, 2 Replies
    03-18-2013 02:08 PM
    Can the description be changed for custom templates (see attached image). If so, how?
    Please use plain text.
    blair
    Re: Can you change template descriptions?
    03-18-2013 09:32 PM in reply to: cbuckthree
    Yes, it's just the file name. The directory path is given in the top of the header when you are selecting your template. Simply rename the file.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    *Pro
    03-19-2013 03:37 AM in reply to: cbuckthree
    Pretty sure that description is built into the dialog box, not a property of the templates themselves.  You can verify this for yourself, though-- create a new part file from the standard template, then change it to sheet metal and save it to your templates folder.  The description in the New dialog box is the standard sheet-metal description, not the standard ordinary part description.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 2
    Windows 7 Enterprise 64-bit, SP1
    HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
    SpaceExplorer/SpaceNavigator NB, driver 3.16.2
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
