• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Can't save to Style Library
    89 Views, 2 Replies
    01-21-2013 08:12 AM
    Can sameone help about this
    Please use plain text.
    Re: Can't save to Style Library
    01-21-2013 11:35 AM in reply to: avi120
    The image you posted shows the steps for updating FROM the styles library, which is the opposite of saving to the styles library.  You have to select the option to save to the styles library (shown below):
    If this command is not available, then your project file probably has the styles library set to read-only status.  You will need to change this:
    -cwhetten
    Please click "Accept as Solution" if this response answers your question.
    Active Member
    01-21-2013 11:46 AM in reply to: cwhetten
    Thank You.
