• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Can't move unconstrained parts within an assembly
    521 Views, 6 Replies
    11-08-2012 08:40 AM
    Hi, I have been building an assembly and suddenly I am unable to move parts according to their constraints. I can move them as soon as they are placed but as soon as I add one constraint it's as if they are glued in place. For example, when I line up two holes I can no longer rotate one part around the grounded component.
    Have a turned off some functionality of the program?
    Any help would be much appreciated!
    Ben
    Please use plain text.
    Valued Contributor
    Re: Can't move unconstrained parts within an assembly
    11-16-2012 01:50 PM in reply to: ben_walker5
    I'm having this same problem, hopefully there is an easy quick fix.
    *Pro
    11-18-2012 01:11 PM in reply to: KF090
    There should be quite a few threads in this forum over the last several years that discuss this problem.  Unfortunately there is no quick fix-- it seems that Inventor can get confused in certain assemblies, and there is no solution other than deleting a bunch of constraints and starting over.  But do some searching and see if there's any more guidance from people with the benefit of experience.
    *Expert Elite*
    blair
    11-18-2012 03:28 PM in reply to: ben_walker5
    Look for a bad constraint, this seems to freeze parts, also having a second part selected in the browser will do the same thing as well.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.0 / 4.11
    Valued Mentor
    stephengibson76
    11-19-2012 01:59 AM in reply to: ben_walker5
    do as the others have suggested, but just to get you out of trouble if it needs to go out the door...
    Although you can not drag the component, you may be able to move it by adding additional constraints, just add them as you would normally would and see if it moves correctly
    Stephen Gibson
    Autodesk Product Design Suit 2012
    Win 7 Enterprise 64bit
    Intel core i7 2600K Clocked @ 4.7GHz
    16Gb Ram
    Nvidia GTX 580
    Employee
    t_stramr
    11-21-2012 05:05 AM in reply to: ben_walker5
    Hi Ben,
    Could you attach your assembly? If you have some simple assembly that exhibits the problem I can take a look closer for source of the problem.
    Thank you,
    Robert
    Active Contributor
    rjezuit
    11-21-2012 11:02 AM in reply to: t_stramr
    I have had this issue also, in 2010, 2011, and 2012.  It seems to be related to previously placed parts that are grounded. If I "un ground" parts placed before the one that is messed up it seems to free them up. Then I ground the previously un grounded parts.
