• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    frumious_Bandersnatch
    Can't get extrude dialog box back on-screen without second monitor attached
    247 Views, 2 Replies
    11-11-2012 05:41 PM
    Normally I use two monitors, but I'm travelling.  Because I last placed the extrude box on my other monitor I can no longer get access to it on the only screen I have left.  Normally, as with any window, you could hit Alt+Space and M but....the blasted mini-toolbar takes focus first!!  It seems that all the other menus don't have this, only extrude.  Is there any way to reset menus when disconnecting?  There really should be. I'd say that the program ought to know that there is only one monitor connected and respond accordingly.
    W7-64, all up to date
    Please use plain text.
    Valued Mentor
    Re: Can't get extrude dialog box back on-screen without second monitor attached
    11-12-2012 04:52 AM in reply to: frumious_Bandersnatch
    The mini toolbar is a pain as far as I am concerned.
    There is a registry setting for the position of these things... I will see if I can dig it up For you.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    Product Support
    11-14-2012 08:33 AM in reply to: frumious_Bandersnatch
    Take a look at this.
    http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html and / or
    http://www.youtube.com/user/JustinHoey#p/u/4/rRP9sWpFYBM and / or
    AT You Own Risk
    registry is in HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionxx.0\DockingAreas
    Don
