• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Can only create Single User Project
    69 Views, 1 Replies
    07-20-2012 06:14 AM
    I've just recieved a new pc with Win7 64bit (no admin access) and AIS 2008 SP3.
    When I go to Projects>New, the only option is new Single user Project. How can I enable the other project types or what can cause them not to show up?
    Jon C.
    Please use plain text.
    sam_m
    Re: Can only create Single User Project
    07-20-2012 06:30 AM in reply to: Cnoj
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1480-Work_Env1480/1481-Work_en...
    Semi-isolated Master, Semi-Isolated Workspace, and Shared are all legacy projects
    We recommend that you use Autodesk Vault Basic to manage multi-user projects. In the Project wizard, Semi-isolated and Shared project types are unavailable by default. If you have a requirement to create legacy projects types, click Tools tab  Options panel  Application Options General tab. Select the Enable creation of legacy project types check box
    Also note that Win 7 only supports Inventor 2010 SP1 and newer - so you might have issues with that also...
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
