• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Can I Disable Command Alias Input Dialogs?
    216 Views, 1 Replies
    06-06-2012 09:22 AM
    When I create a rectangular box in Autodesk Inventor 2008, shell it, and create a new sketch on any face and press E I expect to be greeted with the extrusion options. This does not happen, and a command alias input dialog appears in the status bar.
    I really want to turn this off, since it has happened on other occasions as well. Since there's no other way to get to the extrusion feature, it completely halts my work.
    Usually when I don't know what a feature is for and I'm not attempting to use it I expect to not see it- especially when I perform actions that don't usually bring it up. I'm not sure why the behavior has been put there. Hopefully it's not put into later versions (I've seen 2010 complaints as well) so someday an upgrade will remove the annoyance.
    Please use plain text.
    Curtis_Waguespack
    Re: Can I Disable Command Alias Input Dialogs?
    06-06-2012 09:29 AM in reply to: mason52
    Hi mason52,
    If you go to Tools > Application Options > General tab, do you see an option called "Show Command alias input dialog" or something similar? If so does unchecking that help?
    Also look for an option called "Show command prompting (Dynamic Prompts)".
    I can't recall what was in Inventor 2008, but I think these options are there.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
