• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Calculation of paint area
    146 Views, 2 Replies
    11-08-2012 06:38 AM
    How can Inventor calculate the paint area of a one-side open container with a double bottom?
    The container should be painted at the inside and outside.
    But not the hollow space between the double bottom and the real bottom?
    Kind regards
    Jan
    Please use plain text.
    Valued Mentor
    mpatchus
    Re: Calculation of paint area
    11-08-2012 07:14 AM in reply to: janlsing
    Two options...
    1. Select all of the surfaces that you want to include, RMB Measure Area.
    2.  Make the "hollow" portion of the double bottom the last element of the part.
    Now slide the EOP above the last element and bring up your iProperties.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    11-08-2012 07:18 AM in reply to: janlsing
    You could even model the paint and get the volume of paint needed.
    Derive Component as surface body and Thicken for the paint.
       (or do as multi-body solid)
    What version of Inventor are you using (I can post a 2013 example).
