• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    Calculating the weight of a part?
    239 Views, 4 Replies
    11-14-2012 12:29 PM
    I would like to find the actual weight of a part in pounds.
    I have attached one of the parts I would like to know the total pounds or ounces for.  I’m using a specific material that I set in the Physical tab of iProperties.
    Version = Inventor Pro 2009
    Thank You,
    Bill J.
    Please use plain text.
    *Expert Elite*
    Re: Calculating the weight of a part?
    11-14-2012 12:42 PM in reply to: billjenkins
    look at the "physical" tab of the iproperties..
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Valued Contributor
    11-14-2012 01:34 PM in reply to: mcgyvr
    I see 4.184 lbmass (Rela listed in the Mass Window under General Properties located in the Physical tab. Does this mean the part has a weight of 4.184 pounds?
    I hope it’s this easy.
    Bill
    GSE_Dan_A
    11-14-2012 01:57 PM in reply to: billjenkins
    Good afternoon Bill,
    Yes it really is that easy!  Ensure your material/ density is correct and the value given in the Mass box is correct!  You may need to hit Update if you have made any changes to the part.
    GSE Consultants Inc.
    Windsor, ON. Canada
    Valued Contributor
    11-14-2012 04:36 PM in reply to: GSE_Dan_A
    Thanks to all. This is really helpful and so easy. I try to figure stuff out but there have been several times that I would have been stuck without the assistance I’ve received here.
    I do have another question regarding setting up the desired accuracy but I’ll ask about that in a new message.
    Bill
