• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Cable and Harness Length Control
    135 Views, 3 Replies
    01-17-2013 12:28 AM
    Hi!
    I'm creating a wire assembly and i already have in me a length for my wire.
    How can I apply this in my assembly for Inventor? It seems only the diameter can be specified but not the length.
    Please help.
    Please use plain text.
    Re: Cable and Harness Length Control
    01-17-2013 03:53 AM in reply to: ericjed13
    I couldn't understand your question sir!
    01-17-2013 10:44 PM in reply to: sohmoh
    I'm talking about the Cable and Harness Environment in Inventor Pro.
    i wanna know if Inventor has this function wherein I could enter or adjust the desired length of wire in my Harness Assembly?
    Active Contributor
    jonathanruffray
    01-18-2013 12:20 AM in reply to: ericjed13
    you have to placed your 2 points you used to create your wire at the distance you need... Or if the wire is not a "right" line but a spline (As for many wiring) and it's to hard to adjust the lenght by the routing you could force the length in the BOM of your part.
    John.
    Autodesk Product Design Suite Ultimate 2013
    Win 7 Pro 64 bits SP1
    Bi-Xeon E5520 (2x Quad-core @2.27GHz)
    Quadro Fx 1800 768Mo GDDR3
    6Go Ram DDR3 667MHz ECC
