Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
CPU & Inventor 2012/2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
when I use a PC with more then one CPU can Inventor 2012/2013 use then all, or is it only running on one CPU?
BR
Tom
Re: CPU & Inventor 2012/2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For most of its use Inventor only uses 1 core. The main things that take advantage of multiple cores/cpus are rendering, fea and with 2012 (and newer) each idw view is rendered/calculated with a separate core.
Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
Lithium - helping nntp users with mania, depression and headaches
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This isn't just an Inventor limitation, unless someone's come up with something new in the past few years that I didn't get the memo on. The problem is with any 3D CAD application, each feature in a model tree has to be fully computed before the next one can. Only one processor can work on a feature at a time, hence only one processor gets used.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't think FEA uses multiple cores. At least it doesn't when I use it (I REALLY wish it did...). I've only ever seen it run 1. Maybe it does in 2013, but not in 2012.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can confirm that R2013 FEA (Stress Analysis) can utilize as many cores as your machine has for meshing and solving. It is managed by the Windows O/S multi-core technology.
Hope this helps!
Best regards, -Hugh
Hugh Henderson
Simulation QA Engineer
DLS (Simulation and Material Sciences)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I agree the limitation that each feature in a model tree has to be fully computed before the next one can.
But there are many other time consuming tasks that could be distributed to multiple cores. As an example I do a lot of configurations in Inventor where one skeleton part is derived into many parts.
When I make changes in the skeleton part, perhaps 100 parts should be updated in the assembly. Each part could easily be calculated in its own process.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
DSS have figured out how to use more than 1 core at part level iin Catia - so it is possible, the question is now how long will it take autodesk programmers to figure out how to do it.
