• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    .CFG files for Wiring
    120 Views, 2 Replies
    11-29-2012 07:21 PM
    I can't seem to find the .cfg files that supposedly come with autocad Inventor to manipulate and export wiring information.  I've done a complete search of all my autodesk folders but it just doesn't seem to be anywhere.
    Is there a place online where this file is mirrored and can be downloaded or copied?
    Alan
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: .CFG files for Wiring
    11-29-2012 08:58 PM in reply to: alanbailey1
    Hi alanbailey1,
    I think you'll need to download the sample files to find an example *.cfg file:
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13923228&linkID=9242019
    Once downloaded look for a sample at some path such as this:
    ...\Inventor 20xx\Cable & Harness\Samples\Wire List Import
    I don't have the exact path in front of me at the moment.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    jonathanruffray
    Re : .CFG files for Wiring
    12-03-2012 04:40 AM in reply to: alanbailey1
    Hello Alan,
    Are you not looking for your wires and harness library with list all yopu cabkle components?
    In this case you should search for an *.iwl files and not *.cfg. It should be
    ../Design data/Cable & Harness/fr-FR/Cable&HarnessDefaultLibrary.iwl
    You have to replace "fr-fr" by your localization....
    John.
    Autodesk Product Design Suite Ultimate 2013
    Win 7 Pro 64 bits SP1
    Bi-Xeon E5520 (2x Quad-core @2.27GHz)
    Quadro Fx 1800 768Mo GDDR3
    6Go Ram DDR3 667MHz ECC
