• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    CAN'T RETRIEVE PUBLISH PART IN LIBRAIRY
    82 Views, 1 Replies
    10-10-2012 08:33 AM
    I am trying to publish a i-part to the librairy.  I follow the process and everything and it is suppose to be successful (see attached).  But after that, I can't retrieve this item in the librairy.
    Is someone know why.
    Using INV 2012 with SP2 installed.
    Please use plain text.
    Active Member
    Re: CAN'T RETRIEVE PUBLISH PART IN LIBRAIRY
    10-24-2012 10:22 AM in reply to: ddgenifab
    I did a test this morning with Inventor 2010 installed and I am able to publish a part in the librairy.
    Doing the same exact thing (same part) with INV 2012 and it do not work !  In both case, the step are the same and I have the "publish successeful" promt.  In INV 2012, I just can't see the part published in the librairy.
    Does someone know anything about this?  Is there a SP for INV 2012 for part publishing that I have to install ?
