• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    WAYNE_HOUWD
    Buckling Analysis Function?
    265 Views, 3 Replies
    06-12-2012 07:32 PM
    I tried to find the buckling analysis from Inventor FEA but no clue. I searched here and found 1 related thread almost 4 years ago.
    http://forums.autodesk.com/t5/Autodesk-Inventor/How-to-get-the-buckling-effect/m-p/2386440#M323302
    I am wondering if Autodesk has improved some on this particular analysis for these years ?
    Best Regards,
    Wayne
    Please use plain text.
    Distinguished Mentor
    Re: Buckling Analysis Function?
    06-12-2012 08:07 PM in reply to: WAYNE_HOUWD
    No not yet, still only static and modal.
    Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
    Stew, AICP
    Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
    Windows 7 x64 Core i7 32GB Ram FX2000
    01-04-2013 04:58 AM in reply to: WAYNE_HOUWD
    I would like to see buckling analysis in inventor too and i am sure many others would as well, when is it likley to happen?  is it being worked on?
    regards Adrian
    Rory_M
    01-04-2013 05:20 AM in reply to: WAYNE_HOUWD
    Have you had a look at the column calculator? It does some buckling calcs but obviously is limited when compared to FEA techniques. It can't cope with anything other than straight extrusions either but it's better than nothing.
