• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    KFrankenberger
    Breaking dim extension lines as they cross over other dim extension lines...
    661 Views, 7 Replies
    11-29-2011 07:54 AM
    I'm using Inventor 2011 and I can't figure out how to set my dimension settings so it breaks the dimension extension lines automatically when crossing over other dimension extension lines.  I saw that others say it just happens, but it is not "just happening" for me.  Can someone explain how to set my dimensions so when dimension lines cross each other one of them automatically breaks?
    Thanks.
    Please use plain text.
    *Pro
    Re: Breaking dim extension lines as they cross over other dim extension lines...
    12-04-2011 05:49 PM in reply to: KFrankenberger
    In 2011 (and 2012), extension lines only break around dimension text.  I've never seen them break around other extension or dimension lines.
    Active Contributor
    KFrankenberger
    12-05-2011 10:05 AM in reply to: KFrankenberger
    That is unfortiunate. So I guess there is no way to break them? In regular AutoCAD (haven't used it in a while but I used 2008, I think) you exploded dimensions and could adjust them however you wanted after you exploded them.
    Employee
    12-07-2011 06:47 AM in reply to: KFrankenberger
    Hi, there was a logged a WISH item for that (DID#924303). I have added your comments to the defect.
    Ladislav
    Active Contributor
    KFrankenberger
    12-07-2011 08:22 AM in reply to: t_pcoll
    Does that mean next time they make a new version of Inventor they might consider adding the ability to explode dimensions so you can break dim lines around each other manually?
    12-07-2011 10:24 AM in reply to: KFrankenberger
    actually, there is "dimbreak" command in autocad for that :smileyhappy:
    Active Contributor
    KFrankenberger
    12-07-2011 10:42 AM in reply to: vakhtang
    Is there a "dimbreak" command in Inventor for that? I couldn't find one.
    11-15-2012 08:19 PM in reply to: KFrankenberger
    still waiting for the solution is it available in 2013
