• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Breaking Dimensions in Inventor
    795 Views, 7 Replies
    04-09-2009 12:54 PM
    Is there a way to break dimensions in Inventor like in Autocad? It automatically breaks around certain things, but I'm wondering if there is any way to control this.
    Please use plain text.
    *Igor Mironenko
    Re: Breaking Dimensions in Inventor
    04-09-2009 06:31 PM in reply to: twblack
    I think there is. As an example of what can be done
    please see the attached. For the specific case you might have you need to
    provide some more info.
    Igor.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Is
    this.
    04-10-2009 04:40 AM in reply to: twblack
    Thanks, but that is not what I was talking about. I have attached an example. What I am trying to do is control the break size so that the break extends beyond the dimension line on the 130 dimension. I would also like to be able to break the 130 extension line around the 65 dimension line.
    *Igor Mironenko
    04-10-2009 07:26 PM in reply to: twblack
    I see. Inventor does it automatically. Please have
    a look at the attached. The variable "C" controls the gap between the dim text
    and Dim line and although the offset from the dim line. That in return prevents
    you from making the break larger without increasing the text offset from dim
    line.
    Igor.
    04-13-2009 04:43 AM in reply to: twblack
    So, there is no way then to break the extension line around the dimension line?
    *Tim King \(Autodesk\)
    04-13-2009 09:09 AM in reply to: twblack
    You are correct. Inventor does not have this capability at this time.
    Tim
    wrote in message news:6160935@discussion.autodesk.com...
    line?
    Active Member
    03-01-2013 12:33 AM in reply to: *Tim King \(Autodesk\)
    How 'bout now?
    Tim
    line?
    Active Contributor
    hansome_one
    03-04-2013 01:53 PM in reply to: twblack
    I don't think that there is a setting that you are looking for, but i do have a work around that might work for you.  Try doing this and see if it works for you.
    1. Edit Dimension (RMB) dialog box.
    2. Hit return to start a new line of text under your dimension.
    3. Now, hit your space bar only ONE time.  This will extend your whole text dialog box (its invisible to the user) down.  If that does not get you down far enough, that repeat steps 2 & 3.
    Good Luck
    2013 Ultimate Suite
     W7
    2013 IV Design Suite Ultimate
    W 7 - 64 bit
    i7 - 3.50 ghz Overclocked
    12g Ram - 2000 Nvidia
