• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Mentor
    Ktelang
    Break View at an Angle
    178 Views, 3 Replies
    06-25-2012 11:51 AM
    Hello Everyone,
    Any trick to make create a break view along a sloping edge.
    So that the view still appears continuous rather that the one
    shown in attached pic.
    Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
    Inventor 2013 and Vault Basic 2013
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Break View at an Angle
    06-25-2012 01:05 PM in reply to: Ktelang
    Hi Ktelang,
    Unfortunately it isn't possible, but it has been requested in the past. You can add your feedback at the Autodesk feedback link:
    You can request enhancement and new features using the Feed Back link:
    http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Mentor
    Ktelang
    06-25-2012 01:48 PM in reply to: Curtis_Waguespack
    Thanks Curtis
    New Member
    mechdsn
    01-14-2013 10:29 AM in reply to: Ktelang
    A possible "work-around" would be to break the views alignment to its parent view and then rotate the view to a horizontal or vertical orientation. Then, you can use the break view command as normal and add the angle of rotation to the view label that was generated automatically. I would typicallly add something like "VIEW ROTATED 60 CCW" (counter clockwise). Most shops can work with that without too much confusion. It would be great if Autodesk would allow broken angled views in the next release though...
