• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Bolted connection follow pattern not work
    250 Views, 6 Replies
    06-13-2012 01:03 AM
    Bolted connection follow pattern not work. When i use  follow pattern  in Bolted connection  component not pattern
    Please use plain text.
    *Expert Elite*
    cbenner
    Re: Bolted connection follow pattern not work
    06-13-2012 04:04 AM in reply to: rgruychev
    In your picture, I see all of the holes highlighted... looks like it's following the pattern.  That screen shot doesn't show the completed process, does it not insert fasteners in all of the highlighted holes?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    *Expert Elite*
    06-13-2012 04:12 AM in reply to: rgruychev
    Feature pattern or Component pattern?
    Attach your assembly here.
    06-13-2012 05:47 AM in reply to: rgruychev
    *Expert Elite*
    06-13-2012 06:28 AM in reply to: rgruychev
    Your holes are placed at the assembly level, not at the part level.  (open part and there are no holes)
    Is this what you intended?
    06-13-2012 06:48 AM in reply to: JDMather
    How use command follow patter when i have holes in assembly level?
    10-11-2012 06:40 AM in reply to: cbenner
    Im having  a similar problem... its shows the wireframe view as though its going to place multiple screws in the assembly, but when i click apply, It places all the multiple holes but only shows 1 bolt on the first refernce that i choose. why does it not place all the bolts when placing the holes.
    Thanks, Craig
