• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    nickhowe
    Accepted Solution
    Bolted Connection between non-parallel surfaces?!
    135 Views, 1 Replies
    06-01-2012 01:43 AM
    Having trouble bolting through a beam onto a tappered face of a channel. In RL a tapered washer would be used,  though they exist in Content Centre it doesnt help the application.
    Any Ideas?!!
    Please use plain text.
    Re: Bolted Connection between non-parallel surfaces?!
    06-04-2012 01:27 PM in reply to: nickhowe
    I do a lot of that, and it is truely annoying. The taper angle on the content center washer is not the same as the angle on the content center channel so constraining them together doesn't work right.
    What I do is:
    1. Constrain CL of hole in channel to CL of hole in washer
    2. Constrain the tip edge of the beveled washer to the face of the channel flange
    3. now the flat face of the washer is parallel to the flat face of the channel and bolted connection will work.
