• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Bolted Connection Templates disappeared
    118 Views, 6 Replies
    10-04-2012 06:03 AM
    I've lost my Bolted Connection Templates... you know, the pre-defined bolt-washer-nut selections available for re-use at the bottom of the Bolted Connection dialoge box.
    Did I lose or over-write a file?  What file do my Bolted Connection Templates live in?
    John
    Please use plain text.
    *Pro
    jletcher
    Re: Bolted Connection Templates disappeared
    10-04-2012 06:56 AM in reply to: jdavis417
    Please post version of Inventor...................... :smileyhappy:
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    10-04-2012 07:12 AM in reply to: jletcher
    Oh, it's 2012 !
    (...not simulation... Design Suite?)
    I was trying to think of what had changed recently and I DID have to delete my windows-user profile and re-create it to solve some "oddness" that Inventor was doing... could I have pathed myself away from my previously-customized file?
    Thanks again,
    John
    *Pro
    jletcher
    10-04-2012 07:34 AM in reply to: jdavis417
    Yes you could have you may want to check.
    James Letcher
    10-04-2012 07:52 AM in reply to: jletcher
    ...but I don't know what file to check for and where...?!
    *Pro
    jletcher
    10-04-2012 08:02 AM in reply to: jdavis417
    Who made the templates? And where was they placed. You could do a search for .xml files and look to see if you can find them. But if you don't know I would not they don't come pre loaded they are made and saved.
    James Letcher
    10-04-2012 10:58 AM in reply to: jletcher
    I created the previous "templates"...
    I made a new "test" template and (finally) found it here...
    C:\Users\...\AppData\Roaming\Autodesk\Inventor 2012\DesignAccelerator\Templates\CABoltCon
    I think I have a backup of my previous "templates", but will have to do it in my "spare time".
    I'll try post back here if I find any exceptions or anything that might help others who may have to wipe-out their Windows Profile, as I did.
    John
