• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Vitornis
    Bolted Connection Problem
    708 Views, 7 Replies
    04-21-2011 10:16 AM
    Im using the bolted connection tool and when i chose all of circluar reference and pick out my bolt and nut the tool will only draw one bolt and ignore all the other circular references.  It previews all the bolts just fine ut will only place a bolt in one of the circular references.
    Please use plain text.
    Distinguished Contributor
    Re: Bolted Connection Problem
    04-22-2011 01:21 PM in reply to: Vitornis
    As far as I know, you can only place one Bolted Connection at a time.  Would be nice to be able to place multiple instances of it.
    IV2012
    Windows XP SP3 32-bit
    Intel Core 2 Duo 6400 @ 2.13 GHz
    Nvidia Quadro FX 3450/4000 SDI 256MB Vram
    2 GB Ram
    160GB HDD
    04-22-2011 01:51 PM in reply to: zma1013
    Actually  if it is a pattern you can place multiple instances at once if you use Pattern Feature ( and checkmark the Follow Pattern box).
    I just checked using Concentric reference and that worked on multiple holes at once in 2012.
    Valued Contributor
    Vitornis
    04-22-2011 02:45 PM in reply to: JDMather
    Well my problem has been that most of the time the concentric refernece works on multiple hole most of the time. But on some instances it wont and i haven't been able to figure out why it works sometime and other times it doesn't.
    New Member
    Zypo88
    06-08-2011 12:57 PM in reply to: Vitornis
    This problem gave me headaches for a good month, and as usual with such things the answer is frustratingly simple.
    If you select the face of the first hole using "Concentric" then it will only generate the first bolt, but if you select the edge of the first hole then all the rest should generate fine.  In my experience that is the only thing that effects bolt generation, doesn't matter if it's individual holes or a pattern.
    New Member
    03-21-2013 01:26 PM in reply to: Vitornis
    As a solution, after generating the "hidden bolted connection", go to its node in the model tree. Right click and choose "flexible"! Then the connection will jump on the screen.
    03-21-2013 02:27 PM in reply to: Vitornis
    I guess if one has only a few bolts Bolted Connection might work, but if you have alot of them it will slow you down considerably. best bet is to make a bolt assembly library and insert them into your model as needed. Just make one for the largest grip size and they will work for anything within the grip range. Table ensures enough thread past nut with one washer and enough thread at smallest grip. personally I never use bolted connection as it bogs down inventor.
    Steven White
    Lee C. Moore, Inc.
    www.lcm-wci.com
    Inventor 2011
    Intel Dual Xeon E31225 @ 3.1 GHz CPU
    16 GB RAM
    NVIDIA Quadro 600 GPU
    Windows 7 - 64 Bit
    LT.Rusty
    03-21-2013 04:22 PM in reply to: swhite
    Odd that everyone's saying you can pattern bolted connections ... I just did about 12 of them, and the "follow pattern" checkbox is there when I'm using preexisting holes.
    ___________________________________________________________
    Product Design Suite Ultimate 2013
    Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
    Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
