• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Bolted Connection - Failing to stay constrained
    267 Views, 6 Replies
    01-11-2010 01:35 PM
    I've been having an issue with my bolted connection - when I check to follow pattern or if I pick multiple holes the bolted connection doesn't stay locked down by constraints - it still wants to rotate about the first picked hole axis. When I have used bolted connection in the past it would always remain completely constrained. Would anyone happen to know why this is? Thanks
    Please use plain text.
    *Blair Stunder
    Re: Bolted Connection - Failing to stay constrained
    01-11-2010 04:08 PM in reply to: schwebby
    Version and SP's
    IV2010-Pro-sp2
    Vista Business 64bit Sp2
    Core i7 950 @ 3.07Ghz
    12Gb DDR3-1600, 240Gb (4 x 60 Gb SSD - RAID0)
    Quadro FX3800 - 191.78
    SpacePilot 3.8.3 / 6.8.1
    AVG9.0
    "schwebby" wrote in message news:6316345@discussion.autodesk.com...
    01-12-2010 07:46 AM in reply to: schwebby
    Sorry - Inventor 2010 SP 1
    *Ohap
    01-13-2010 04:53 AM in reply to: schwebby
    Hello
    unfortunatelly , as far as I know it is as designed. Workaround for that is
    to add a new own constrain on a one bold in the pattern to constrain ti with
    a part. Then it works well. And also you have to check if something changes
    with pattern that BC is on right possition.
    regards
    "schwebby" píše v diskusním příspěvku
    __________ Informace od ESET NOD32 Antivirus, verze databaze 4763 (20100112)
    __________
    Tuto zpravu proveril ESET NOD32 Antivirus.
    http://www.eset.cz
    __________ Informace od ESET NOD32 Antivirus, verze databaze 4766 (20100113) __________
    http://www.eset.cz
    01-14-2010 07:23 AM in reply to: schwebby
    I find this hard to believe - it has worked in the past where the bolted connection is locked down - I have been noticing this issue for the past 3 weeks - thought it was maybe something with old projects i'm working in?
    01-20-2010 08:23 AM in reply to: schwebby
    well - after trying a new project and assembly the bolted connection still rotates about the selected hole axis. I'm thinking it might be the way Inventor 2010 does the bolted connection - I'll have to try it again in Inventor 2009 and see if the bolted connection stays constrained.
    Valued Mentor
    jeanchile
    01-31-2010 10:01 PM in reply to: schwebby
    I too am having this issue, and I am unable to add an additional constraint without getting the "overconstrained" prompt. I'll spare the long stories but it seems the easiest thing for me to do is recreate this bolted connection each time after altering the model. Is there any news or information about why this would do this or what I could do differently?
    IV2010 SP1
    Vista Ultimate SP2 Edited by: jeanchile on Feb 1, 2010 6:01 AM
    Inventor Professional 2013 (SP-1.1), Product Design Suite Ultimate
    Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (314.07), Space Pilot Pro (3.16.1)
    Laptop: Intel Core 2 Duo T9600 @ 2.8GHz, 8.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTS 160M (314.07), SpaceNavigator (3.16.1)
