• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    nickhowe
    Bolted Connection Component Generator Problems
    211 Views, 5 Replies
    04-27-2012 12:05 AM
    Hi
    I have been using the bolted Connection utility and have found that it takes a long time accessing the content centre (up to a minute) for the fasteners. Sometimes it flashes the fasteners window up for as millisecond and then cancells it. Is this a bug?
    Cheers
    Nick
    Please use plain text.
    Active Contributor
    nickhowe
    Re: Bolted Connection Component Generator Problems
    04-27-2012 01:26 AM in reply to: nickhowe
    ....also I'm having trouble seeing all of the folders through the generator even though I can see them all when i place from the Content Center.
    For example I have three folders of types of washers, the Component Generator only offers me one type from one folder.
    It's driving me insane!
    *Expert Elite*
    cbenner
    04-27-2012 07:42 AM in reply to: nickhowe
    What version of Inventor?  Is your Content Center Vault or Desktop?  Can you attach a screen shot of what you are seeing in the BC Generator that doesn't look right?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Active Contributor
    nickhowe
    04-30-2012 11:45 PM in reply to: cbenner
    Hi Chris
    Attached a couple of picxs showing the problem. The Content Center is a modified desktop center (soon to Vault) for our use with alternative fixing descriptions that required us to "turn off" the other standards. We just arent seeing the whole of the library left over when using the "bolted connection" tool.
    Cheers
    Nick
    Active Contributor
    nickhowe
    04-30-2012 11:58 PM in reply to: nickhowe
    Sorry, also to mention. The speed issue cleared up with the deleting of most of the standards. I expect it was trying to form a Vault link or something.
    Regards
    Nick
    Valued Contributor
    05-10-2013 04:19 AM in reply to: nickhowe
    I'm seeing the slow down as well on all of our workstations.
    And the one workstation that connects from farther away is having the the same empty or missing standards issue.
    We use Vault as the Content Center.
    Any news yet?
