Bolt Connection and hole location update
02:03 PM
I have a frame member and a plate bolted together using the bolt connection feature. I moved the frame member slightly and while the bolt and nut moved the hole in the plate did not. Do I have to redo the connection when I adjust the position of parts to get the hole to stay in line with the bolt?
Link copied
