• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Bolt Circle Centerline to Non-Circles .idw
    296 Views, 3 Replies
    12-04-2012 08:20 AM
    I have a ratchet plate idw that I've drawn and dimensioned, but I would like to insert two bolt circles to the two diameter dimensions that appear to be pointing at nothing. The circular pattern is not made up of circles so I haven't been able to use the Centered Pattern command in the centerline section. I'm using Inventor 2013.
    Please use plain text.
    Re: Bolt Circle Centerline to Non-Circles .idw
    12-04-2012 08:23 AM in reply to: houtchenswho
    Either
    Retrieve sketch from ipt
    or
    click on view and hit S on keyboard.
    Project Geometry center circle and two points on teeth.
    Sketch circles.
    Exit sketch.
    New Member
    12-04-2012 08:59 AM in reply to: JDMather
    I would like to mention that after creating the circles, I had some trouble formatting them to centerline, until I realized this option was under the right click menu in properties. Thank you
    *Pro
    12-05-2012 05:01 AM in reply to: houtchenswho
    The other method to change line styles is while you are in the sketch, change to the Annotate tab and select the approriate layer in the Format panel.
