Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Bolt Circle Centerline to Non-Circle s .idw
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a ratchet plate idw that I've drawn and dimensioned, but I would like to insert two bolt circles to the two diameter dimensions that appear to be pointing at nothing. The circular pattern is not made up of circles so I haven't been able to use the Centered Pattern command in the centerline section. I'm using Inventor 2013.
Re: Bolt Circle Centerline to Non-Circle s .idw
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Either
Retrieve sketch from ipt
or
click on view and hit S on keyboard.
Project Geometry center circle and two points on teeth.
Sketch circles.
Exit sketch.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would like to mention that after creating the circles, I had some trouble formatting them to centerline, until I realized this option was under the right click menu in properties. Thank you
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The other method to change line styles is while you are in the sketch, change to the Annotate tab and select the approriate layer in the Format panel.
