• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Blending a miter
    161 Views, 2 Replies
    10-05-2012 10:30 AM
    I am creating part files for one of our machines, and have no idea how to proceed with making a smooth transition on the bevel, like it is showing on the print from our customer.
    What would be the best way to accomplish this?
    Thank you very much for your help.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
    ACAD Mechanical 2013
    Please use plain text.
    Curtis_Waguespack
    Re: Blending a miter
    10-05-2012 10:58 AM in reply to: sps_cad_guy
    Hi sps_cad_guy,
    Attached is a quick example file. You didn't mention the version of Inventor you're using so I did this in Inventor 2010 (that's as far back as I can go at this point), so I hope you can use the file.
    I've used two methods in this file, one for when the blend exceeds the chamfer size and one for when it doesn't. There are probably some other solutions as well, but this is the approach that I use.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    10-05-2012 11:05 AM in reply to: Curtis_Waguespack
    Thank you Curtis. That was exactly what I've needed to do.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
