• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Triton, Mark
    Bleed Thru Continues
    72 Views, 11 Replies
    11-18-2002 12:16 AM
    . . . and the bleed thru problem continues in printing and/or plotting even
    after SP1 is installed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Hidden edges
    showing in shaded views!!!!!!!!!!!!!!
    Do I need to show another example in CF??? I've been complaining about this
    since Beta 2!!!!!!!!!!! I thought this was to be fixed!!!! Shaded views
    are also looking very "cartoonish" with heavy black outlines and poor color
    quality!!!!!!!! I am going to post a sample in CF - material is white
    delrin - idw created in IV5.3 (or 5, or 4 - can't remember). The second
    sample (idw) was created just now - bleed thru gone. So it appears that
    shaded views in old (pre-IV6 SP1) idw's will not print/plot properly. Am I
    correct in my assumption?
    The graphics driver is fully certified.
    The graphics driver ID is NVIDIA Corporation\Quadro/AGP/SSE\1.2.2
    Graphics driver file nv4_disp.dll is version 5.13.01.1241
    Using Full optimization (this is the recommended setting)
    SwapType = 4
    Workarounds = 0x00000000
    Workarounds2 = 0x00000002
    The display is using 32-bit color
    HW Library Version = Win2K - $Revision: #3 $
    HW Library Date = $DateTime: 2002/11/11 13:09:54 $
    Options = 0
    Warning Options = 15
    Settings for optimized and conservative:
    SwapType: 4, 2
    Workarounds: 0x00000000, 0x00000000
    Workarounds2: 0x00000002, 0x00000040
    Text Options: 0x00000002, 0x00000000
    OpenGL Version: 12, 12
    Recommended Optimization Level: 2
    Texture Font Precision: 32
    Stroke Font Precision: 0.001000
    Driver Rating: 3
    Inventor Version Tested: 6070a
    Using OpenGL 1.1
    swap behavior: saveRestore(4)
    OpenGL errors: None.
    Please use plain text.
    *Dotson, Sean
    Re: Bleed Thru Continues
    11-18-2002 12:22 AM in reply to: *Triton, Mark
    Mark,
    might want to save the Paint Shop Pro images as JPEGs. Not all of us have
    Paint Shop Pro...
    I'll have to check some of my older files. I do not see the bleed thru on
    files created in R6.
    Sean Dotson, PE
    http://www.sdotson.com
    ...sleep is for the weak..
    "Mark Triton" wrote in message
    news:0A1C709BFC959787F327096F1BC7317A@in.WebX.maYIadrTaRb...
    even
    this
    color
    I
    > SwapType = 4
    > Options = 0
    > SwapType: 4, 2
    > Driver Rating: 3
    > Using OpenGL 1.1
    *Triton, Mark
    Re:
    11-18-2002 12:32 AM in reply to: *Triton, Mark
    Sorry - I meant to save them as JPEGs. Will redo. The bleed thru does not
    seem to happen on files created in R6 - only previous idw's.
    Mark
    "Sean Dotson" wrote in message
    news:12C4FFB82CD62445CF04CD20EB7D0CDF@in.WebX.maYIadrTaRb...
    > Mark,
    > Paint Shop Pro...
    > Sean Dotson, PE
    > even
    > this
    views
    > color
    Am
    > I
    > > SwapType = 4
    > > Options = 0
    > > SwapType: 4, 2
    > > Driver Rating: 3
    > > Using OpenGL 1.1
    Distinguished Contributor
    11-18-2002 01:14 AM in reply to: *Triton, Mark
    Can't say for the bleed thru but have to agree, Inventor 6 SP1 shaded views do look very cartoonish (great if this is required but possibly a wee bit unprofessional looking compared to IV5.3)
    Regards
    Matt Hutchinson
    *Rasmussen, Ed
    Re:
    11-18-2002 02:18 AM in reply to: *Triton, Mark
    I have a part that was created in R6 SP0.  In
    my first drawing using SP1 this morning,  I kept getting the bleed through
    in print preview and paper prints of one of the two shaded views I made of that
    part.  I edited the view and changed to hidden line removed and then
    changed again back to shaded.  That view now previews and prints with no
    bleed through.  I don't know if that process will consistently fix any
    views with bleed through, but you might want to try it.
            Ed
    R
    Can't
    Regards
    Matt
    Hutchinson
    *QA\, Autodesk Inventor
    Re:
    11-18-2002 02:57 AM in reply to: *Triton, Mark
    I believe that if you highlight the view in
    the browser and click on the Update button, it will accomplish the same
    thing--and you should not see any bleed-through when you print after doing the
    Update.
    In my first drawing using SP1 this morning,  I kept getting the bleed
    through in print preview and paper prints of one of the two shaded views I
    made of that part.  I edited the view and changed to hidden line removed
    and then changed again back to shaded.  That view now previews and prints
    with no bleed through.  I don't know if that process will consistently
    fix any views with bleed through, but you might want to try it.
            Ed
    R
    Can't
    Regards
    Matt
    Hutchinson
    *Rasmussen, Ed
    Re:
    11-18-2002 03:05 AM in reply to: *Triton, Mark
    Thanks.  I will try that on the next one that
    shows that problem.
        Ed R
    Update.
    removed and then changed again back to shaded.  That view now previews
    and prints with no bleed through.  I don't know if that process will
    consistently fix any views with bleed through, but you might want to try
    it.
            Ed
    R
    Can't
    Regards
    Matt
    Hutchinson
    *Rasmussen, Ed
    Re:
    11-18-2002 03:28 AM in reply to: *Triton, Mark
    When I highlight the view in the browser, there is
    no Update button available that I can see.  I have tried RMB and pull
    downs.
            Ed
    R
    Update.
    it.
            Ed
    R
    Can't
    Regards
    Matt
    Hutchinson
    *KJohnson
    Re:
    11-18-2002 03:52 AM in reply to: *Triton, Mark
    That does not help trails that bleed through.
    Kathy Johnson
    Update.
    it.
            Ed
    R
    Can't
    Regards
    Matt
    Hutchinson
    *Triton, Mark
    Re:
    11-18-2002 04:54 AM in reply to: *Triton, Mark
    Dottie -  YES - that trick worked for me (at
    least on the first drawing I tried it on).  Hopefully it will continue to
    clear up this problem on the other drawings!  THANK YOU!!!!!!
    Mark
    Update.
