• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Bill of Materials shows unused iparts
    124 Views, 1 Replies
    09-19-2012 12:10 PM
    So I have an iassembly with iparts in an .iam file and I went to make a shop drawing of this assembly. When I go to do this, I get my parts list showing all versions of the iparts, even the ones that are not used. It will show a 0 in quantity.
    This is under the "structured" view and I do not see a "pars" tab, which is what I've read I need to look for.
    I've read that I have to be very careful with the way that I create iassemblies and iparts, so if someone could clarify the rules behind these things and if someone could help me figure out how to make a drawing with a BOM that only shows the parts currently in use, I would greatly appreciate this.
    Cheers,
    Vijai Sookrah
    Mechanical Engineer, EIT
    Aircraft Appliances & Equipment Ltd.
    Please use plain text.
    Valued Mentor
    Ktelang
    Re: Bill of Materials shows unused iparts
    09-19-2012 12:21 PM in reply to: vsookrah
    Hope this helps
    Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
    Inventor 2013 and Vault Basic 2013
