• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Bill of Materials Question
    375 Views, 23 Replies
    04-27-2012 10:30 AM
    I would like to create a bill of materials where I can get the total length of each part used.  In other words I have something called PART A and I might have 6 or 7 of them at different lengths.  I want to get a total length of the material used.  My parts list is showing each one listed as its own part with individual lengths.  How do I convert this?
    Steve Frey
    Inventor 2013
    Windows 7 Professional 64-bit SP1
    HP EliteBook 8470w
    Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
    Memory: 16 GB
    AMD FirePro M2000
    3D Connexion SpacePilot
    Please use plain text.
    Valued Mentor
    japike
    Re: Bill of Materials Question
    04-27-2012 10:36 AM in reply to: SteveFrey
    Can you give all of them the same part number so that they combine on your parts list?
    Peace,
    Jeff
    Inventor 2013
    04-27-2012 10:42 AM in reply to: japike
    Yes.  They all have the same part number.  So items #3 and #4 would be combined.  So would #13 and #14.  See attached.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    Valued Mentor
    japike
    04-27-2012 10:56 AM in reply to: SteveFrey
    In your BOM there is a button called "Part Number Row Merge Settings" if you select that there should be a check box called "Enable Row Merge on Part Number Match". Is that checked?
    Peace,
    Jeff
    Inventor 2013
    04-27-2012 11:18 AM in reply to: japike
    yes
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    Product Support
    04-27-2012 04:24 PM in reply to: SteveFrey
    Steve,
    Can you post a small subset assembly of your data that just contains items #3 and #4 and  #13 and #14?
    Or you can send it privately to me if you don't want to post publicly (bob.van.der.donck@autodesk.com)?
    Thanks.
    Bob
    Valued Mentor
    Rich.O.3d
    04-29-2012 05:51 PM in reply to: bobvdd
    something to check...
    are you using susbstitution on the qty or unit qty columns in your part list?
    have a look at the substition tab for them, do they show first value or sum of values in the 'when rows are merged....'
    the unit qty one should sum them (or at least i seem to remember that it used to in earlier versions)
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    04-29-2012 06:53 PM in reply to: Rich.O.3d
    I'm not exactly sure.  I will have to wait until I get into work tomorrow to answer this.  in the meantime can you post a screenshot of this?  Thanks.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    Valued Mentor
    Rich.O.3d
    04-29-2012 07:39 PM in reply to: SteveFrey
    see attachment
    CAD Management 101:
    04-29-2012 07:45 PM in reply to: Rich.O.3d
    Thanks.  I will check first thing in the morning.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
