• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    hagiographa
    Bill of Materials - Parts and Assemblies merge under one part number
    275 Views, 2 Replies
    08-04-2011 07:55 PM
    I am having trouble with balloons.  Multiple items have the same item number.
    Somehow they have merged, and appear as a single item in the BOM and Parts List.
    How can I un-merge them?  I just want each part and sub assembly to have their own item number.
    At the moment in the BOM, both 'Structured' and 'Parts Only' have "Enable BOM view" checked.
    When I created the drawing, everything was fine.  It only occurred when I re-opened the file.
    I'm sure it's an easy fix, but I just don't know what that is.
    I've attached an image which might help.
    Please use plain text.
    Curtis_Waguespack
    Re: Bill of Materials - Parts and Assemblies merge under one part number
    08-04-2011 08:34 PM in reply to: hagiographa
    Hi hagiographa,
    This happens when the components (parts and/or assemblies) have the same part number. To resolve this you can either go to the Model Data tab of the BOM editor and edit the part numbers as needed to make them unique, or you can click the Part Number Row Merge Settings button and uncheck the Enabel Row Megre on Part Number Math box.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    hagiographa
    08-04-2011 09:03 PM in reply to: Curtis_Waguespack
    Hi Curtis,
    Thanks, that did the trick.
    I knew it would be something simple, but I just couldn't work out what setting and where to change it.
    It would've taken me hours to find.   :smileyhappy:
