Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Bi-Directi onal Patterning
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a way to do both directions when doing a linear pattern?
One direction having "x" amount of instances and theother direction having a different amount?
Scott McFadden
(Colossians 3:23-25)
Re: Bi-Directi onal Patterning
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't think that is possible with one pattern. You could do two patterns from the same feature.
Jeff
Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yeah, I am not seeing a way myself. That is why I posed the question in hopes that I was
overlooking something or maybe someone has figured out a way around this.
I did try whay you suggested in reusing the original parts used in the first pattern, but when I try it, it wants to
grab all of the patterned parts from the first pattern along with it. I am still on 2012 so maybe this functionality
is more enhanced in 2013 or different to the point where it does work as you are describing.
Right now my thinking is to just reinsert these same parts into the location where I need it.
Scott McFadden
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry, I didn't realize you were talking about component patterns. My example was for feature patterns.
Jeff
Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm sorry. I should have been clearer.
My bad!!!! ![]()
Scott McFadden
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Component patterns suck in Inventor. I don't know why AutoDesk neglects them so much, but it's a point of constant frustration.
Having said that, what is it that your trying to do? Could you accomplish it using the reuse feature pattern tool?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Mike,
You are certainly not going to get any arguments from me on that one!!!
I am sorry to say that the feature patterning tool will not help in this case.
I have a case where these parts in my iassembly factory for one of the iassemblies pattern one direction
"x" amount of times then increase in quantity for the other iassembly, but require to not only increase in the
same direction as the first, but go in the opposite direction as well.
What I ended up doing is in the second iassembly, changing the starting point to the beginning on the second
iassembly and it didn't screw up my first iassembly as I originally thought it might.
I have since placed an enhancement request in with Autodesk to add this functionality in the component patterening tool. Other softwares have it, why not Inventor.
Scott McFadden
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is one possibility that may or may not be suitable for what you need.
1. Start the rectangular component pattern command, and pick the direction you want.
2. Set the quantity to half of the total.
3. Set your distance between components.
4. Use the second direction pick and choose the SAME direction as the first pick, but flip it.
5. Set the quantity to 2. (This effectively doubles the quantity in step 2).
6. Set the second distance to be the first distance times the first quantity. If you already have parameters for these values, just use those; if you don't, you will have to set some dummy value, click OK, then re-edit the pattern and use the model parameters instead (it will end up something like d3*d5).
The above directions apply for an even-numbered pattern. A few tweaks will get you an odd-numbered pattern (slightly different second distance formula, and the last component suppressed). Also, this is for centered, symmetric patterns (although you could use it for a pattern that is asymmetrical by one occurrence in either direction).
I have attached an assembly and a part showing two examples of this (one example for an even-numbered pattern, and one for an odd-numbered pattern).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Chris,
Tried this method and it worked like a charm. Infact when it was done in fron t of my VAR they were estonished to the point they were going to publish it as a tip and trick.
Scott McFadden
